[gdal-dev] gdal_polygonize.py binding error
Xiaodong Zhang
xiaodong.zhang2 at und.edu
Fri Jan 7 12:47:47 EST 2011
Hi Chaitanya,
Setting PYTHONPATH did solve the problem. The new gdal-python bindings
were installed under /user/local/lib64/python2.4/site-packages and the
path was not set automatically. It would be nice if the sys.path is
modified automatically by gdal installation.
Thanks
Xiaodong
Xiaodong Zhang, Ph. D
Associate Professor
Department of Earth System Science and Policy
University of North Dakota
Tel: (701) 777-6087
http://www.und.edu/instruct/zhang
On 1/6/2011 10:11 PM, Chaitanya kumar CH wrote:
> Xiaodong,
> Check again after setting the environment variable PYTHONPATH to the
> path to the new python bindings.
> On Fri, Jan 7, 2011 at 12:55 AM, Xiaodong Zhang
> <xiaodong.zhang2 at und.edu <mailto:xiaodong.zhang2 at und.edu>> wrote:
> Hi,
> I just updated the older version of gdal (1.4.2) with the latest
> version of gdal (1.7.3) on x64 RedHat. Got an error when using
> gdal_polygonize.py for a test image
> gdal_polyzonize.py t2.tif -f "ESRI Shapefile" pt2
> gdal.Polyzonize() not available. You are likely using "old gen"
> bindings or an older version of the next gen bindings.
> I found the previous threads on this issue, but could not find an
> answer.
> Any idea? Thanks
> Xiaodong
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110107/12c88422/attachment.html
