[gdal-dev] Hierarchical Data Format-EOS 2 conversion in Gdal
Nikolaos Hatzopoulos
nhatzop at gmail.com
Mon Jan 10 15:31:15 EST 2011
what gdalinfo gives you?
this is a very helpful link http://www.gdal.org/frmt_hdf4.html
On Mon, Jan 10, 2011 at 10:19 AM, Adam Bausch <abausch at nova.whrc.org> wrote:
> Hi All,
> I am attempting to process a large volume of MERIS mosaic data obtained
> from ENVISAT in HDF-EOS2 format, however, I continue to get a "not a
> supported format" error when I try to run it. I have installed the HDF-4
> (libdf), HDF-5 (libhdf5) and NetCDF libraries and checked with our
> Linux/Unix administrator to try and identify the problem with no resolution.
> I was wondering if anyone else has had this problem or if there is a fix.
> Best,
> Adam
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110110/91ec867e/attachment.html
