[gdal-dev] mrsid nmake.opt
Kirk McKelvey kmckelvey at lizardtech.com
Wed Jan 12 19:26:19 EST 2011
Good call Jeff, I will revise the MrSID wiki.
> -----Message d'origine-----
> De : gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-
> bounces at lists.osgeo.org] De la part de Jeff McKenna
> Envoyé : Tuesday, January 11, 2011 5:09 AM
> À : gdal-dev at lists.osgeo.org
> Objet : Re: [gdal-dev] mrsid nmake.opt
> Thanks Kirk, I'll give it a whirl.
> Also, I wonder if we need to update anything on the MrSID wiki page:
> http://trac.osgeo.org/gdal/wiki/MrSID
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 11-01-10 9:05 PM, Kirk McKelvey wrote:
> > All,
> > I have made a change to simplify build configuration for the mrsid
> > driver on the trunk (r21458). If you regularly build this driver,
> > especially if you have a vested interest in maintaining compatibility
> > with a particular historical MrSID SDK release, please give it a whirl
> > and let me know if you have any trouble with it.
> > Previously it was a manual and iterative process to get the MRSID_* vars
> > correct for a given SDK release - especially if it was an older one. Now
> > you should just have to set MRSID_DIR and that's it, even using older
> > MrSID SDKs.
> > The work is done in a new file, frmts/mrsid/nmake.opt, which is
> > !INCLUDEd from gdal/nmake.opt. If you have an interest in the windows
> > build harness and the patience to examine this file I would appreciate
> > hearing any feedback or concerns about the approach I took.
> > Tamas, from what I understand you have tweaked the layout of the MrSID
> > SDK used in your daily windows builds. Depending on the details this
> > might work for you anyway; if it doesn't, let me know.
> gdal-dev mailing list
