[gdal-dev] GDAL/OGR 1.8.0RC1 Release Candidate Prepared
Greg Coats
gregcoats at mac.com
Wed Jan 12 23:18:34 EST 2011
ls shows that every file and directory has the same (false) modification date and time. This makes it impossible to see when a particular source code file was actually last updated. Can the final GDAL source code be released with accurate modification dates and times? Greg
On Jan 12, 2011, at 10:20 PM, Frank Warmerdam wrote:
> Folks,
> I have prepared a release candidate for GDAL/OGR 1.8.0. The source,
> testsuite and documentation can be found at:
> http://download.osgeo.org/gdal/gdal-1.8.0RC1.tar.gz
> http://download.osgeo.org/gdal/gdal180RC1.zip
> http://download.osgeo.org/gdal/gdal180doc.zip
> http://download.osgeo.org/gdal/gdalautotest-1.8.0.tar.gz
> I would appreciate broad testing of the release candidate and reporting
> problems via Trac tickets:
> http://trac.osgeo.org/gdal/
> If things seem respectible I will introduce a motion to promote this
> release candidate as a final 1.8.0 release in the next day or two.
> Note that as part of the 1.8.0 release candidate process I have established
> a GDAL/OGR 1.8 stable branch, and tagged the source used for the release
> candidate as 1.8.0:
> http://svn.osgeo.org/gdal/branches/1.8
> http://svn.osgeo.org/gdal/tags/1.8.0
> Any bug fixes intended for 1.8.x releases, including a possible 1.8.0RC2
> need to be ported into the 1.8 stable branch starting now.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
