[gdal-dev] GDAL Java Bindings and HDF4 File format
Sam Ritchie sritchie09 at gmail.com
Tue Jan 18 14:20:05 EST 2011
Hey all,
Short question first, then the longer explanation.
*QUESTION*: My java SWIG bindings, generated from source, can't read the
HDF4 format. How can I fix this?
*CONTEXT*:
I've spent the last couple of days trying to generate java bindings for gdal
that will allow me, essentially, to run this piece of java code --
https://svn.osgeo.org/fdo/tags/3.4_G032/Thirdparty/gdal/swig/java/apps/gdalinfo.java
gdal.AllRegister() works great, but I can't get past gdal.Open(), as the
bindings don't recognize HDF4.
My final goal is to create a maven package that has gdal.java and the native
dependencies bundled up together. This way, I can run jobs on NASA's MODIS
tiles on Elastic MapReduce, simply by making sure the MapReduce nodes have
gdal and hdf4 installed locally (using apt-get gdal-lib).
I built from source, using ./configure --with-hdf4=/opt/local/
--with-hdf5=/opt/local/ (macports versions). I CDed into swig, ran make,
then CDed into java, and ran make again. This gave me gdal.java, plus all of
the native dependencies as dylibs, which I moved to a directory on
java.library.path.
I wrote this piece of code to test my setup: https://gist.github.com/784850
Now, that code, as it runs now, returns this-  "(my file path)
It doesn't recognize the HDF file, even though I specified --with-hdf4.
*So, my question is,* *what special things do I need to do to get make java
swig-bindings to recognize these damn formats?* Do I have to specify
something about swig when I run ./configure initially? (BTW, I'm running on
Mac OS X, and also had to tweak the java path settings inside java.opt.
ALL I need to be able to do, really, is open up the hdf file and extract the
subdatasets. I plan on writing an article describing how to run GDAL on
Amazon's Elastic MapReduce, after I'm done with all of this stuff.
Thanks in advance, everyone!
Sam Ritchie
Forest Monitoring for Action
http://www.cgdev.org/section/initiatives/_active/forestmonitoringforactionforma
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110118/3f2f61a7/attachment.html
