[gdal-dev] Create a shape file with polygons
Jorge Martin jormarfe at gmail.com
Wed Jan 19 03:15:54 EST 2011
Hello Frank,
I have made your change and it works, I can open the .shp with my GIS. Many
thanks for your help.
Best Regards,
Jorge
2011/1/18 Frank Warmerdam <warmerdam at pobox.com>
> On 11-01-18 11:28 AM, Jorge Martin wrote:
>> OGRPolygon myPoligon;
>> tmp = strtok (Line, ":");
>> szName = string (tmp);
>>        while (tmp != NULL)
>>        OGRLinearRing MyRing;// = (OGRLinearRing*)
>> OGRGeometryFactory::createGeometry(wkbLinearRing);
>>         tmp = strtok (NULL, ",");
>>         if(tmp)
>>                string Coords = string(tmp);
>>               size_t pos = Coords.find(" ");
>>               string CoordX = Coords.substr(0,pos);
>>               string CoordY = Coords.substr(pos);
>>               x = atof(CoordX.c_str());
>>                y = atof(CoordY.c_str());
>> MyRing.addPoint(x,y);
>>         myPoligon.addRing(&MyRing);
> Jorge,
> The essence of your problem is that you are creating a new
> ring for each point instead of creating one ring for the
> polygon and adding all the points to that ring before adding
> the ring to the polygon.  A slightly altered form of the core
> that works looks like:
>        while (tmp != NULL)
>            if(tmp)
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110119/22297d9a/attachment.html
