[gdal-dev] MSSQL GDAL 1.8.0 Feature problem
Matthew Blackler
matt at mattblackler.com
Mon Jan 24 03:19:36 EST 2011
Thanks for you prompt response Tamas!
Well, after having used the ogrinfo tool (thanks for the hint - first time
user of ogr/gdal you see), I tested the connection string mutliple times -
and it turns out it was because I was using Initial Catalog parameter,
instead of the Database parameter.
So - handy hint for the day - Don't use the Initial Catalog parameter in
your SQL Server 2008 connection string with OGR. Use the Database
parameter.
Cheers Tamas!
On Sun, Jan 23, 2011 at 11:05 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
> Matthew,
> Could you provide a sample data to reproduce this problem?
> How the layer and the features are displayed by the ogrinfo command tool?
> Best regards,
> Tamas
> 2011/1/23 Matthew Blackler <matt at mattblackler.com>
>> Dear all,
>> I have downloaded v1.8.0 and am using .net CSharp bindings to connect into
>> MSSQL such:
>> "MSSQL:SERVER=MATT-ACERPC\\SQLExpress;tables=categ(geom);Initial
>> Catalog=Crown_GIS;Integrated Security=True";
>> I am able to connect and retrieve the driver ok. I am able to get the
>> Layer "Categ" from the datasource, no problem. However, the extent of the
>> layer, feature counts, and even the "get" of features using the nextfeature
>> cursor fails to retrieve any features or information for me.
>> Any obvious pointers as to why iterating through a layer with a known
>> number of features (4,000 ish) would result in returning nothing (i.e. no
>> feature back from the getnextfeature), or why the extent of a layer would be
>> reported as being 0,0,0,0?
>> Any help would be much appreciated. Looking forward to leveraging OGR to
>> making our apps datasource independant, and throwing away the shackles of
>> ArcObjects!
>> Thanks in advance,
>> Matthew Blackler
>> Email: matt at mattblackler.com
>> Homepage: http://www.mattblackler.com
>> Twitter: @mattblacklercom
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110124/8cec595c/attachment-0001.html
