AW: [gdal-dev] An issue about using GDALWARP todotheNTv2transformation
Schmitz, Uwe uwe.schmitz at bezreg-koeln.nrw.de
Mon Jan 24 04:24:24 EST 2011
Heng,
> Hi Uwe,
> I have been trying to use gdal_merge.py to merge
> a few 8 bit colored .tif tiles together. Having
> tried all sorts of options for this command, I
> always ended up with a merged 8-bit grayscale picture.
> I did a search on the internet and found a couple of
> posts related to this, however it seemed to me that
> the gdal_merge.py just does not have the ability
> to preserve the color. Did I get the wrong idea about
> this? Do you have any suggestion to solve this problem?
you have to specify "-pct" to grab the color table
of the first merged tile for the result file.
And, very important, all input tiles need to have
the *same* color table, because merging is done
on pixel values (that means channels).
> Not sure if I should post a separate message for
> this gdal_merge.py issue.  I just thought this would
> be the quickest way to get the help :)
Yes, IMO a seperate post would have been better and
addressing it to me wouldn't always help to get a fast
response ;-)
Regards
Uwe
