[gdal-dev] Problem with GEOTIFF
Fernando Cacciola
fernando.cacciola at gmail.com
Tue Jan 25 15:09:16 EST 2011
Hello,
I have a geotiff image which, according to its accompaning htm, uses the
WGS_1984 Datum.
However, when I call GDALGetProjectionRef() it fails, returning
"GCS tag not found", plus
ENR_L01.tif (from ENR_L01.zip)
Failed to setup Geographic Coordinate System
FAILED with error: 2
gdalinfo reports:
Driver: GTiff/GeoTIFF
Files: enr_p01.tif
enr_p01.tif.aux.xml
Size is 20000, 7998
Coordinate System is `'
Metadata:
TIFFTAG_SOFTWARE=GPL Ghostscript 8.71
TIFFTAG_DATETIME=2010:12:29 07:58:38
TIFFTAG_XRESOLUTION=400
TIFFTAG_YRESOLUTION=400
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 7998.0)
Upper Right (20000.0, 0.0)
Lower Right (20000.0, 7998.0)
Center (10000.0, 3999.0)
Band 1 Block=20000x1 Type=Byte, ColorInterp=Red
Band 2 Block=20000x1 Type=Byte, ColorInterp=Green
Band 3 Block=20000x1 Type=Byte, ColorInterp=Blue
What can I do?
TIA
Fernando Cacciola
SciSoft Consulting, Founder
http://www.scisoft-consulting.com
