[gdal-dev] Problem with GEOTIFF
Wed Jan 26 21:16:38 EST 2011
On 11-01-25 03:09 PM, Fernando Cacciola wrote:
> Hello,
> I have a geotiff image which, according to its accompaning htm, uses the
> WGS_1984 Datum.
> However, when I call GDALGetProjectionRef() it fails, returning
> "GCS tag not found", plus
> ENR_L01.tif (from ENR_L01.zip)
> Failed to setup Geographic Coordinate System
> FAILED with error: 2
> What can I do?
Fernando,
It might be helpful to see a listgeo report on the tiff file.  Listgeo
is a utility associated with libgeotiff and might already be available on
your system or easily installed.
I haven't been able to identify where the "GCS tag not found" error message
is coming from.  It does not seem to be part of the OGRSpatialReference,
GeoTIFF driver, or libgeotiff code.
Best regards,
