[gdal-dev] projection in external file
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 26 18:07:57 EST 2011
On 11-01-26 08:33 AM, morabit wrote:
> Hi All,
> In our project we have to support the loading of tiff images
> that will be geo-referenced by means of external companion
> files containing the affine geo transformation and projection
> information (WKT).
> We have tested that GDAL supports external geo-transform
> using .tfw files, but we are not able to load WKT info included
> in companion .proj or .wkt files.
> Does GDAL support this kind of feature?
> Perhaps it supports this feature using some other format (aux.xml)?
> In case of positive answer, what is the right way to accomplish this?
Bruno,
Yes, it should be possible to embed a coordinate system in an .aux.xml file
and have GDAL utilize it transparently for GeoTIFF files. I have attached
an example .aux.xml file with a coordinate system and geotransform in it.
Note that the coordinate system is in WKT, but with XML encoding of special
characters like quotes.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110126/d5b1d21c/out.tif.aux.xml
