[gdal-dev] GDAL 1.8 - Switch Thrown
Tamas Szekeres
szekerest at gmail.com
Sat Jan 29 06:14:05 EST 2011
Frank,
I would suggest to include the C# bindings too. I don't think it would be
reasonable to provide the bindings from a separate compilation and not
compiling that along with the GDAL core components.
Best regards,
Tamas
2011/1/29 Frank Warmerdam <warmerdam at pobox.com>
> Folks,
> I have had good success with the GDAL 1.8 upgrade and I have now thrown
> the switch migrating it into the production version of OSGeo4W.
> I have upgraded "gdal", "gdal-python", "gdal-mrsid" and "gdal-autotest".
> I have yet to upgrade the ecw, and sde related drivers, and I have not
> upgraded the java bindings. I will try to work on them tomorrow.
> The gdal15dll package was created for backward compatability and should
> be automatically pulled in. It seems to be working fine for OpenEV.
> I would encourage folks building packages to update, and rebuild them
> using the current GDAL. The GDAL include files in C:\OSGeo4W\include
> and libraries in C:\OSGeo4w\lib should now be for 1.8.
> Note that the new GDAL package is built using Visual Studio 2008
> Express instead of 2003. If you are using the C++ API this may cause
> issues but if you use the C API it should be invisible.
> Let me know of problems.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110129/bfaa57ad/attachment.html
