[gdal-dev] Re: GDAL Error 1: TIFFFetchDirectory:Sanity check on
directory count failed . . .
Even Rouault
even.rouault at mines-paris.org
Sat Jan 29 09:58:30 EST 2011
Le samedi 29 janvier 2011 15:53:30, Neil Best a écrit :
> Thanks, Even. That makes sense. If I understand your suggestion I can
> create a trivial VRT pointing to the input data for each worker, correct?
Yes, that's one possibility. But more simply, provided it is possible through
rgdal framework, you could just open the same tiff file from each worker thread.
