[gdal-dev] Re: GDAL Error 1: TIFFFetchDirectory:Sanity check on
directory count failed . . .
Neil Best
nbest at ci.uchicago.edu
Sat Jan 29 13:23:28 EST 2011
Thank you, Even. I think that did it. Instead of passing around raster()
objects I need to pass the file names and re-instantiate the objects on the
workers within the foreach closure. Are you on Stackoverflow? If not,
please consider signing up. I think it's a great concept and I would like
to give you credit for this solution.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-Error-1-TIFFFetchDirectory-Sanity-check-on-directory-count-failed-tp5972745p5973171.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
