[gdal-dev] export 3D shapefile to 2D (-lco dim=2 not is not used
by the shp driver)
G. Allegri
giohappy at gmail.com
Fri Jul 8 10:10:23 EDT 2011
Great! thanks Chaitanya, -nlt POLYGON did the work ;)
giovanni
2011/7/8 Chaitanya kumar CH <chaitanya.ch at gmail.com>
> Giovanni,
> If your shapefile contains only one type of geometry, you can use the -nlt
> option in ogr2ogr. Using a geometry type without the '25D' postfix should
> remove the Z values.
> On Fri, Jul 8, 2011 at 6:19 PM, G. Allegri <giohappy at gmail.com> wrote:
>> Looking at the shp driver I see that the -lco dim option is not used.
>> Is there another way to tranform a 3D polygon to 2D thorugh ogr2ogr?
>> thanks,
>> giovanni
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110708/11c0da4f/attachment.html
