[gdal-dev] FileGDB OGR driver test
Paul Ramsey
pramsey at opengeo.org
Wed Jul 13 17:54:16 EDT 2011
The fact that sometimes you can see an extent (when you create a FGDB
with OGR) seems to indicate a complexity beyond the driver simply not
reading extents... are you certain this FGDB file has extents set? I
assume it's OK for me to download it and test.
P.
On Wed, Jul 13, 2011 at 2:00 PM, Jeff McKenna
<jmckenna at gatewaygeomatics.com> wrote:
> More feedback on the FileGDB driver:
> - we're trying to access an OSM road network for Colorado, stored in fgb
> format, created with ArcCatalog 10.0
> (ftp://ftp.usace.army.mil/pub/erdc/crrel/rsgis/osm_colo_roads.zip)
> - using gdal-trunk and FileGDB_API_1_0Final
> - when executing ogrinfo for some reason the EXTENT is not displayed in the
> results, such as:
> ogrinfo osm_colo_roads.gdb united_states_united_states_colorado_highway -so
> INFO: Open of `osm_colo_roads.gdb'
> using driver `FileGDB' successful.
> Layer name: united_states_united_states_colorado_highway
> Geometry: Multi Line String
> Feature Count: 106940
> Layer SRS WKT:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4326"]]
> FID Column = OBJECTID
> Geometry Column = SHAPE
> TYPE: String (0.0)
> ONEWAY: String (0.0)
> LANES: Real (0.0)
> Has anyone else noticed this? (testing with OGR-created fgb seems to output
> extents fine)
> Thanks.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
