[gdal-dev] FileGDB OGR driver test
Smith, Michael ERDC-CRREL-NH
Michael.Smith at usace.army.mil
Wed Jul 13 18:05:07 EDT 2011
Yes, it is ok for you to download and test. This is OSM data that I
created using ArcCatalog 10.
Jeff also has a layer of US States that I created from OGR. It did have
the extents.
Mike
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 7/13/11 2:54 PM, "Paul Ramsey" <pramsey at opengeo.org> wrote:
>The fact that sometimes you can see an extent (when you create a FGDB
>with OGR) seems to indicate a complexity beyond the driver simply not
>reading extents... are you certain this FGDB file has extents set? I
>assume it's OK for me to download it and test.
>P.
>On Wed, Jul 13, 2011 at 2:00 PM, Jeff McKenna
><jmckenna at gatewaygeomatics.com> wrote:
>> More feedback on the FileGDB driver:
>> - we're trying to access an OSM road network for Colorado, stored in fgb
>> format, created with ArcCatalog 10.0
>> (ftp://ftp.usace.army.mil/pub/erdc/crrel/rsgis/osm_colo_roads.zip)
>> - using gdal-trunk and FileGDB_API_1_0Final
>> - when executing ogrinfo for some reason the EXTENT is not displayed in
>>the
>> results, such as:
>> ogrinfo osm_colo_roads.gdb united_states_united_states_colorado_highway
>>-so
>> INFO: Open of `osm_colo_roads.gdb'
>> using driver `FileGDB' successful.
>> Layer name: united_states_united_states_colorado_highway
>> Geometry: Multi Line String
>> Feature Count: 106940
>> Layer SRS WKT:
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0,
>> AUTHORITY["EPSG","8901"]],
>> UNIT["degree",0.0174532925199433,
>> AUTHORITY["EPSG","9122"]],
>> AUTHORITY["EPSG","4326"]]
>> FID Column = OBJECTID
>> Geometry Column = SHAPE
>> TYPE: String (0.0)
>> ONEWAY: String (0.0)
>> LANES: Real (0.0)
>> Has anyone else noticed this? (testing with OGR-created fgb seems to
>>output
>> extents fine)
>> Thanks.
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
