[gdal-dev] FileGDB OGR driver test
Smith, Michael ERDC-CRREL-NH Michael.Smith at usace.army.mil
Wed Jul 13 18:07:21 EDT 2011
Or anyone to download and test, just so its clear.
Mike
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 7/13/11 3:05 PM, "Smith, Michael ERDC-CRREL-NH"
<Michael.Smith at usace.army.mil> wrote:
>Yes, it is ok for you to download and test. This is OSM data that I
>created using ArcCatalog 10.
>Jeff also has a layer of US States that I created from OGR. It did have
>the extents.
>Mike
>Mike
>Michael Smith
>On 7/13/11 2:54 PM, "Paul Ramsey" <pramsey at opengeo.org> wrote:
>>The fact that sometimes you can see an extent (when you create a FGDB
>>with OGR) seems to indicate a complexity beyond the driver simply not
>>reading extents... are you certain this FGDB file has extents set? I
>>assume it's OK for me to download it and test.
>>P.
>>On Wed, Jul 13, 2011 at 2:00 PM, Jeff McKenna
>><jmckenna at gatewaygeomatics.com> wrote:
>>> More feedback on the FileGDB driver:
>>> - we're trying to access an OSM road network for Colorado, stored in
>>>fgb
>>> format, created with ArcCatalog 10.0
>>> (ftp://ftp.usace.army.mil/pub/erdc/crrel/rsgis/osm_colo_roads.zip)
>>> - using gdal-trunk and FileGDB_API_1_0Final
>>> - when executing ogrinfo for some reason the EXTENT is not displayed in
>>>the
>>> results, such as:
>>> ogrinfo osm_colo_roads.gdb united_states_united_states_colorado_highway
>>>-so
>>> INFO: Open of `osm_colo_roads.gdb'
>>>      using driver `FileGDB' successful.
>>> Layer name: united_states_united_states_colorado_highway
>>> Geometry: Multi Line String
>>> Feature Count: 106940
>>> Layer SRS WKT:
>>> GEOGCS["WGS 84",
>>>    DATUM["WGS_1984",
>>>        SPHEROID["WGS 84",6378137,298.257223563,
>>>            AUTHORITY["EPSG","7030"]],
>>>        AUTHORITY["EPSG","6326"]],
>>>    PRIMEM["Greenwich",0,
>>>        AUTHORITY["EPSG","8901"]],
>>>    UNIT["degree",0.0174532925199433,
>>>        AUTHORITY["EPSG","9122"]],
>>>    AUTHORITY["EPSG","4326"]]
>>> FID Column = OBJECTID
>>> Geometry Column = SHAPE
>>> TYPE: String (0.0)
>>> ONEWAY: String (0.0)
>>> LANES: Real (0.0)
>>> Has anyone else noticed this? (testing with OGR-created fgb seems to
>>>output
>>> extents fine)
>>> Thanks.
>>> -jeff
>>> Jeff McKenna
>>> MapServer Consulting and Training Services
>>> http://www.gatewaygeomatics.com/
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
