[gdal-dev] Compile problems: gdal-svn with geos-svn
Andreas Neumann
a.neumann at carto.net
Thu Jul 14 09:12:10 EDT 2011
I tried to compile the most-recent gdal-svn with the most recent
geos-svn and got the following error message during compilation:
/bin/grep: /usr/lib/libgeos_c.la: No such file or directory
/bin/sed: can't read /usr/lib/libgeos_c.la: No such file or directory
libtool: link: `/usr/lib/libgeos_c.la' is not a valid libtool archive
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/home/an/dev/cpp/gdal'
make: *** [check-lib] Error 2
Also, i pointed gdal to geos in /usr/local/lib, not in /usr/lib with
the configure params.
Do you have any idea on how I can resolve the issue?
Here are my configure params:
./configure --with-python --with-curl --with-expat
--with-libtiff=internal --with-geos=/usr/local/bin/geos-config
--with-pg=/usr/local/pgsql/bin/pg_config --with-xerces
--with-oci-lib=/usr/local/lib/instantclient_10_2
--with-oci-include=/usr/local/lib/instantclient_10_2/sdk/include
--with-mysql --with-jpeg=internal --with-sqlite --with-spatialite
--with-grass=/usr/local/grass-6.4.0RC5/
Thanks,
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
