[gdal-dev] Compile problems: gdal-svn with geos-svn
Even Rouault
even.rouault at mines-paris.org
Thu Jul 14 12:33:31 EDT 2011
Selon Andreas Neumann <a.neumann at carto.net>:
> Hi,
> I tried to compile the most-recent gdal-svn with the most recent
> geos-svn and got the following error message during compilation:
> /bin/grep: /usr/lib/libgeos_c.la: No such file or directory
> /bin/sed: can't read /usr/lib/libgeos_c.la: No such file or directory
> libtool: link: `/usr/lib/libgeos_c.la' is not a valid libtool archive
> make[1]: *** [libgdal.la] Error 1
> make[1]: Leaving directory `/home/an/dev/cpp/gdal'
> make: *** [check-lib] Error 2
> Also, i pointed gdal to geos in /usr/local/lib, not in /usr/lib with
> the configure params.
It might be that there's some -L/usr/lib that found its way in the linking line,
due to another unrelated lib located there.
I somehow remember having being caught by this libgeos_c.la issue, and I believe
I just renamed that file to something else. An alternative would be to build
GDAL --without-libtool.
> Do you have any idea on how I can resolve the issue?
> Here are my configure params:
> ./configure --with-python --with-curl --with-expat
> --with-libtiff=internal --with-geos=/usr/local/bin/geos-config
> --with-pg=/usr/local/pgsql/bin/pg_config --with-xerces
> --with-oci-lib=/usr/local/lib/instantclient_10_2
> --with-oci-include=/usr/local/lib/instantclient_10_2/sdk/include
> --with-mysql --with-jpeg=internal --with-sqlite --with-spatialite
> --with-grass=/usr/local/grass-6.4.0RC5/
> Thanks,
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
