[gdal-dev] Compile problems: gdal-svn with geos-svn
Andreas Neumann
a.neumann at carto.net
Fri Jul 15 03:51:32 EDT 2011
Thanks - it works if I compile --without-libtool
Whats the drawback of not including libtool? I do not understand
whether it is important/necessary.
Thanks,
Andreas
On Thu, 14 Jul 2011 18:33:31 +0200, Even Rouault wrote:
> Selon Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> I tried to compile the most-recent gdal-svn with the most recent
>> geos-svn and got the following error message during compilation:
>> /bin/grep: /usr/lib/libgeos_c.la: No such file or directory
>> /bin/sed: can't read /usr/lib/libgeos_c.la: No such file or
>> directory
>> libtool: link: `/usr/lib/libgeos_c.la' is not a valid libtool
>> archive
>> make[1]: *** [libgdal.la] Error 1
>> make[1]: Leaving directory `/home/an/dev/cpp/gdal'
>> make: *** [check-lib] Error 2
>> Also, i pointed gdal to geos in /usr/local/lib, not in /usr/lib
>> with
>> the configure params.
> It might be that there's some -L/usr/lib that found its way in the
> linking line,
> due to another unrelated lib located there.
> I somehow remember having being caught by this libgeos_c.la issue,
> and I believe
> I just renamed that file to something else. An alternative would be
> to build
> GDAL --without-libtool.
>> Do you have any idea on how I can resolve the issue?
>> Here are my configure params:
>> ./configure --with-python --with-curl --with-expat
>> --with-libtiff=internal --with-geos=/usr/local/bin/geos-config
>> --with-pg=/usr/local/pgsql/bin/pg_config --with-xerces
>> --with-oci-lib=/usr/local/lib/instantclient_10_2
>> --with-oci-include=/usr/local/lib/instantclient_10_2/sdk/include
>> --with-mysql --with-jpeg=internal --with-sqlite --with-spatialite
>> --with-grass=/usr/local/grass-6.4.0RC5/
>> Thanks,
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Andreas Neumann
Switzerland
