[gdal-dev] build error from svn
David Burken
dburken at comcast.net
Sun Jul 17 13:01:59 EDT 2011
Even,
See below with more info, looks like there are multiple defined things
including external cpl_serv.h. Hope this helps.
Dave
On 07/16/2011 03:12 PM, Frank Warmerdam wrote:
> Folks,
> I should have mentioned more widely, I have written up a ticket on
> this issue at:
> http://trac.osgeo.org/gdal/ticket/4162
> I presume the problem occurs with an external libgeotiff but haven't yet tried
> to reproduce the problem.
> Best regards,
> On Sat, Jul 16, 2011 at 7:06 AM, Even Rouault
> <even.rouault at mines-paris.org> wrote:
>> Selon David Burken<dburken at comcast.net>:
>> Dave,
>> I presume you build GDAL against external libgeotiff, and not internal
>> libgeotiff. In any case, it is weird because cpl_serv.h should be installed when
>> installing libgeotiff (I've just verified it with libgeotiff from svn). So I
>> presume the include paths in the GDAL compilation line might miss a directory ?
>> Can you give more elements ?
I have a third party directory that I install libtiff, libgeotiff, geos,
proj4 to. It's "/work/osgeo/local". To avoid confusion I totally
removed my /work/osgeo/local/include directory and did make installs
from scratch. This is a Fedora 14 build.
My gdal is configured with:
#!/bin/sh
# File: mygdalconfig.sh
# Note: Python needed for QGIS.
prefix=/work/osgeo/local
./configure --prefix=${prefix} --with-kakadu=/work/drb/kakadu/latest
--with-geos=/work/osgeo/local/bin/geos-config
--with-libtiff=/work/osgeo/local --with-geotiff=/work/osgeo/local
--with-mrsid=/work/drb/mrsid/Geo_DSDK-7.0.0.2167 --with-python
$ svn update
At revision 22734.
$ svn status
? mygdalconfig.sh // my gdal configure script only
$ make
libtool: compile: g++ -g -O2 -Wall -I/work/osgeo/gdal/port
-I/work/osgeo/gdal/gcore -I/work/osgeo/gdal/alg -I/work/osgeo/gdal/ogr
-I/work/osgeo/gdal/ogr/ogrsf_frmts -DBIGTIFF_SUPPORT -DOGR_ENABLED
-D_REENTRANT -I/work/osgeo/gdal/port -I/work/osgeo/local/include
-I/work/osgeo/local/include -c gt_wkt_srs.cpp -fPIC -DPIC -o
../o/.libs/gt_wkt_srs.o
In file included from /work/osgeo/gdal/port/cpl_port.h:83:0,
from /work/osgeo/gdal/ogr/ogr_core.h:33,
from /work/osgeo/gdal/ogr/ogr_srs_api.h:34,
from /work/osgeo/gdal/ogr/ogr_spatialref.h:34,
from gt_wkt_srs.cpp:38:
/work/osgeo/gdal/port/cpl_config.h:106:0: warning: "HAVE_STDLIB_H" redefined
/work/osgeo/local/include/geo_config.h:5:0: note: this is the location
of the previous definition
/work/osgeo/gdal/port/cpl_config.h:112:0: warning: "HAVE_STRING_H" redefined
/work/osgeo/local/include/geo_config.h:11:0: note: this is the location
gt_wkt_srs.cpp: In function 'int GTIFSetFromOGISDefn(GTIF*, const char*)':
gt_wkt_srs.cpp:2018:54: error: 'CSLTestBoolean' was not declared in this
scope
gt_wkt_srs.cpp:2083:57: error: 'CSLTestBoolean' was not declared in this
scope
gt_wkt_srs.cpp:2206:58: error: 'CSLTestBoolean' was not declared in this
scope
make[2]: *** [../o/gt_wkt_srs.lo] Error 1
make[2]: Leaving directory `/home/work/osgeo/gdal/frmts/gtiff'
make[1]: *** [gtiff-install-obj] Error 2
So I add #include "cpl_string.h" below CPL_ERROR_H_INCLUDED in
gt_wkt_srs.cpp to pick up CSLTestBoolean and then:
make -C gtiff install-obj
make[2]: Entering directory `/home/work/osgeo/gdal/frmts/gtiff'
/bin/sh /work/osgeo/gdal/libtool --mode=compile --tag=CXX g++ -g -O2
-Wall -I/work/osgeo/gdal/port -I/work/osgeo/gdal/gcore
-I/work/osgeo/local/include -c -o ../o/gt_wkt_srs.lo gt_wkt_srs.cpp
from /work/osgeo/gdal/port/cpl_vsi.h:34,
from /work/osgeo/gdal/port/cpl_string.h:34,
from gt_wkt_srs.cpp:37:
In file included from /work/osgeo/gdal/port/cpl_string.h:36:0,
/work/osgeo/gdal/port/cpl_conv.h:69:0: warning: "CPLFree" redefined
/work/osgeo/local/include/cpl_serv.h:163:0: note: this is the location
In file included from /work/osgeo/gdal/port/cpl_string.h:34:0,
/work/osgeo/gdal/port/cpl_vsi.h:170:17: error: declaration of C function
'void* _GTIFcalloc(size_t*)' conflicts with
/work/osgeo/local/include/geo_tiffp.h:103:24: error: previous
declaration 'void* _GTIFcalloc(gsize_t)' here
/work/osgeo/gdal/port/cpl_vsi.h:171:35: error: declaration of C function
'void* _GTIFcalloc(size_t)' conflicts with
/work/osgeo/gdal/port/cpl_vsi.h:170:17: error: previous declaration
'void* _GTIFcalloc(size_t*)' here
/work/osgeo/gdal/port/cpl_vsi.h:173:44: error: declaration of C function
'void* _GTIFrealloc(void*, size_t)' conflicts with
/work/osgeo/local/include/geo_tiffp.h:104:24: error: previous
declaration 'void* _GTIFrealloc(void*, gsize_t)' here
/work/osgeo/gdal/port/cpl_conv.h:63:33: error: declaration of C function
'void* gtCPLMalloc(size_t)' conflicts with
/work/osgeo/local/include/cpl_serv.h:158:15: error: previous declaration
'void* gtCPLMalloc(int)' here
/work/osgeo/gdal/port/cpl_conv.h:64:41: error: declaration of C function
'void* gtCPLCalloc(size_t, size_t)' conflicts with
/work/osgeo/local/include/cpl_serv.h:159:15: error: previous declaration
'void* gtCPLCalloc(int, int)' here
/work/osgeo/gdal/port/cpl_conv.h:65:42: error: declaration of C function
'void* gtCPLRealloc(void*, size_t)' conflicts with
/work/osgeo/local/include/cpl_serv.h:160:15: error: previous declaration
'void* gtCPLRealloc(void*, int)' here
make[1]: Leaving directory `/home/work/osgeo/gdal/frmts'
make: *** [frmts-target] Error 2
>>> Hi Frank, all,
>>> Just fyi, getting build error from svn. Looks like cpl_serv.h is gone
>>> now. See below for minor patch.
>>> Take care,
>>> Dave
>>> $ svn update
>>> At revision 22725.
>>> gt_wkt_srs.cpp:33:22: fatal error: cpl_serv.h: No such file or directory
>>> compilation terminated.
>>> make[1]: *** [../o/gt_wkt_srs.lo] Error 1
>>> make[1]: Leaving directory `/home/work/osgeo/gdal/frmts/gtiff'
>>> make: *** [gtiff-install-obj] Error 2
>>> Compilation exited abnormally with code 2 at Fri Jul 15 15:06:55
>>> Patch:
>>> svn diff frmts/gtiff/gt_wkt_srs.cpp
>>> Index: frmts/gtiff/gt_wkt_srs.cpp
>>> --- frmts/gtiff/gt_wkt_srs.cpp (revision 22725)
>>> +++ frmts/gtiff/gt_wkt_srs.cpp (working copy)
>>> @@ -30,7 +30,9 @@
>>> * DEALINGS IN THE SOFTWARE.
>>> -#include "cpl_serv.h"
>>> +// #include "cpl_serv.h"
>>> + #include "cpl_csv.h"
>>> #include "geo_tiffp.h"
>>> #define CPL_ERROR_H_INCLUDED
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
