[gdal-dev] build error from svn
Even Rouault even.rouault at mines-paris.org
Sun Jul 17 13:58:23 EDT 2011
Selon David Burken <dburken at comcast.net>:
> Even,
> See below with more info, looks like there are multiple defined things
> including external cpl_serv.h.  Hope this helps.
> Dave
Yes, this was helpful. Should be fixed now. See
http://trac.osgeo.org/gdal/ticket/4162#comment:2
Please svn update and retry (after undoing your changes).
> On 07/16/2011 03:12 PM, Frank Warmerdam wrote:
> > Folks,
> > I should have mentioned more widely, I have written up a ticket on
> > this issue at:
> > I presume the problem occurs with an external libgeotiff but haven't yet
> tried
> > to reproduce the problem.
> > Best regards,
> > On Sat, Jul 16, 2011 at 7:06 AM, Even Rouault
> > <even.rouault at mines-paris.org>  wrote:
> >> Selon David Burken<dburken at comcast.net>:
> >> Dave,
> >> I presume you build GDAL against external libgeotiff, and not internal
> >> libgeotiff. In any case, it is weird because cpl_serv.h should be
> installed when
> >> installing libgeotiff (I've just verified it with libgeotiff from svn). So
> I
> >> presume the include paths in the GDAL compilation line might miss a
> directory ?
> >> Can you give more elements ?
> I have a third party directory that I install libtiff, libgeotiff, geos,
> proj4 to.   It's "/work/osgeo/local".  To avoid confusion I totally
> removed my /work/osgeo/local/include directory and did make installs
> from scratch.  This is a Fedora 14 build.
> My gdal is configured with:
> #!/bin/sh
> # File: mygdalconfig.sh
> # Note: Python needed for QGIS.
> prefix=/work/osgeo/local
> ./configure --prefix=${prefix} --with-kakadu=/work/drb/kakadu/latest
> --with-geos=/work/osgeo/local/bin/geos-config
> --with-libtiff=/work/osgeo/local --with-geotiff=/work/osgeo/local
> --with-mrsid=/work/drb/mrsid/Geo_DSDK-7.0.0.2167 --with-python
> $ svn update
> At revision 22734.
> $ svn status
> ?       mygdalconfig.sh  // my gdal configure script only
> $ make
> libtool: compile:  g++ -g -O2 -Wall -I/work/osgeo/gdal/port
> -I/work/osgeo/gdal/gcore -I/work/osgeo/gdal/alg -I/work/osgeo/gdal/ogr
> -I/work/osgeo/gdal/ogr/ogrsf_frmts -DBIGTIFF_SUPPORT -DOGR_ENABLED
> -D_REENTRANT -I/work/osgeo/gdal/port -I/work/osgeo/local/include
> -I/work/osgeo/local/include -c gt_wkt_srs.cpp  -fPIC -DPIC -o
> ../o/.libs/gt_wkt_srs.o
> In file included from /work/osgeo/gdal/port/cpl_port.h:83:0,
>                   from /work/osgeo/gdal/ogr/ogr_core.h:33,
>                   from /work/osgeo/gdal/ogr/ogr_srs_api.h:34,
>                   from /work/osgeo/gdal/ogr/ogr_spatialref.h:34,
>                   from gt_wkt_srs.cpp:38:
> /work/osgeo/gdal/port/cpl_config.h:106:0: warning: "HAVE_STDLIB_H" redefined
> /work/osgeo/local/include/geo_config.h:5:0: note: this is the location
> of the previous definition
> /work/osgeo/gdal/port/cpl_config.h:112:0: warning: "HAVE_STRING_H" redefined
> /work/osgeo/local/include/geo_config.h:11:0: note: this is the location
> gt_wkt_srs.cpp: In function 'int GTIFSetFromOGISDefn(GTIF*, const char*)':
> gt_wkt_srs.cpp:2018:54: error: 'CSLTestBoolean' was not declared in this
> scope
> gt_wkt_srs.cpp:2083:57: error: 'CSLTestBoolean' was not declared in this
> scope
> gt_wkt_srs.cpp:2206:58: error: 'CSLTestBoolean' was not declared in this
> scope
> make[2]: *** [../o/gt_wkt_srs.lo] Error 1
> make[2]: Leaving directory `/home/work/osgeo/gdal/frmts/gtiff'
> make[1]: *** [gtiff-install-obj] Error 2
> So I add #include "cpl_string.h" below CPL_ERROR_H_INCLUDED in
> gt_wkt_srs.cpp to pick up CSLTestBoolean and then:
> make -C gtiff install-obj
> make[2]: Entering directory `/home/work/osgeo/gdal/frmts/gtiff'
> /bin/sh /work/osgeo/gdal/libtool --mode=compile --tag=CXX g++ -g -O2
> -Wall  -I/work/osgeo/gdal/port -I/work/osgeo/gdal/gcore
> -I/work/osgeo/local/include  -c -o ../o/gt_wkt_srs.lo gt_wkt_srs.cpp
>                   from /work/osgeo/gdal/port/cpl_vsi.h:34,
>                   from /work/osgeo/gdal/port/cpl_string.h:34,
>                   from gt_wkt_srs.cpp:37:
> In file included from /work/osgeo/gdal/port/cpl_string.h:36:0,
> /work/osgeo/gdal/port/cpl_conv.h:69:0: warning: "CPLFree" redefined
> /work/osgeo/local/include/cpl_serv.h:163:0: note: this is the location
> In file included from /work/osgeo/gdal/port/cpl_string.h:34:0,
> /work/osgeo/gdal/port/cpl_vsi.h:170:17: error: declaration of C function
> 'void* _GTIFcalloc(size_t*)' conflicts with
> /work/osgeo/local/include/geo_tiffp.h:103:24: error: previous
> declaration 'void* _GTIFcalloc(gsize_t)' here
> /work/osgeo/gdal/port/cpl_vsi.h:171:35: error: declaration of C function
> 'void* _GTIFcalloc(size_t)' conflicts with
> /work/osgeo/gdal/port/cpl_vsi.h:170:17: error: previous declaration
> 'void* _GTIFcalloc(size_t*)' here
> /work/osgeo/gdal/port/cpl_vsi.h:173:44: error: declaration of C function
> 'void* _GTIFrealloc(void*, size_t)' conflicts with
> /work/osgeo/local/include/geo_tiffp.h:104:24: error: previous
> declaration 'void* _GTIFrealloc(void*, gsize_t)' here
> /work/osgeo/gdal/port/cpl_conv.h:63:33: error: declaration of C function
> 'void* gtCPLMalloc(size_t)' conflicts with
> /work/osgeo/local/include/cpl_serv.h:158:15: error: previous declaration
> 'void* gtCPLMalloc(int)' here
> /work/osgeo/gdal/port/cpl_conv.h:64:41: error: declaration of C function
> 'void* gtCPLCalloc(size_t, size_t)' conflicts with
> /work/osgeo/local/include/cpl_serv.h:159:15: error: previous declaration
> 'void* gtCPLCalloc(int, int)' here
> /work/osgeo/gdal/port/cpl_conv.h:65:42: error: declaration of C function
> 'void* gtCPLRealloc(void*, size_t)' conflicts with
> /work/osgeo/local/include/cpl_serv.h:160:15: error: previous declaration
> 'void* gtCPLRealloc(void*, int)' here
> make[1]: Leaving directory `/home/work/osgeo/gdal/frmts'
> make: *** [frmts-target] Error 2
> >>> Hi Frank, all,
> >>> Just fyi, getting build error from svn.  Looks like cpl_serv.h is gone
> >>> now.  See below for minor patch.
> >>> Take care,
> >>> Dave
> >>> $ svn update
> >>> At revision 22725.
> >>> gt_wkt_srs.cpp:33:22: fatal error: cpl_serv.h: No such file or directory
> >>> compilation terminated.
> >>> make[1]: *** [../o/gt_wkt_srs.lo] Error 1
> >>> make[1]: Leaving directory `/home/work/osgeo/gdal/frmts/gtiff'
> >>> make: *** [gtiff-install-obj] Error 2
> >>> Compilation exited abnormally with code 2 at Fri Jul 15 15:06:55
> >>> Patch:
> >>> svn diff frmts/gtiff/gt_wkt_srs.cpp
> >>> Index: frmts/gtiff/gt_wkt_srs.cpp
> >>> --- frmts/gtiff/gt_wkt_srs.cpp    (revision 22725)
> >>> +++ frmts/gtiff/gt_wkt_srs.cpp    (working copy)
> >>> @@ -30,7 +30,9 @@
> >>>     * DEALINGS IN THE SOFTWARE.
> >>> -#include "cpl_serv.h"
> >>> +// #include "cpl_serv.h"
> >>> + #include "cpl_csv.h"
> >>>    #include "geo_tiffp.h"
> >>>    #define CPL_ERROR_H_INCLUDED
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> gdal-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
