[gdal-dev] FileGDB OGR driver test
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jul 18 19:18:35 EDT 2011
More testing feedback:
When displaying in MapServer, a full path is required on Windows (only
Windows, relative paths work on Unix), in the CONNECTION parameter, such as:
FAILS: CONNECTION "filegdb/us_states.gdb"
WORKS: CONNECTION "C:/ms4w/apps/ms101/data/filegdb/us_states.gdb"
I have documented this at http://www.mapserver.org/input/vector/filegdb.html
If others can test this issue: to duplicate, use GDAL-trunk and then try
to display any FileGDB (created with Arc 10.0) in MapServer, on Windows.
And let me know if you succeed. Thanks.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
