[gdal-dev] A map conversion problem with GDAL 1.8.0
Corrado Guarino Lo Bianco
guarino at ce.unipr.it
Sat Jun 4 06:00:35 EDT 2011
Hi all,
I'm a QLandkarteGT user (QLandkarteGT is based on GDAL) and I'm having a
problem related to map formats. I use ecw maps in conjunction with DEM
data stored in geotiff files. In the past I was using GDAL 1.7.2 and I
had no problems. Recently I switched to GDAL 1.8.0 and now QLandkarteGT
says that there is no matching between the projection used for the maps
and that used for DEM data, nevertheless I'm still adopting the same
files. By means of gdalwarp, I have made several unsuccessful attempts
to convert DEM data into a format suitable to be used in conjunction
with ecw maps.
Can someone help me?
These are the outputs I get from the ecw and the tiff files when I run
gdalinfo:
Driver: ECW/ERDAS Compressed Wavelets (SDK 3.x)
Files: /media/IGM 25000/IGM 25.000 - Emilia Romagna.ecw
Size is 96000, 64000
Coordinate System is:
PROJCS["NUTM32",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Origin = (510000.000000000000000,5000000.000000000000000)
Pixel Size = (2.500000000000000,-2.500000000000000)
Corner Coordinates:
Upper Left ( 510000.000, 5000000.000) ( 9d 7'37.99"E, 45d 9'12.26"N)
Lower Left ( 510000.000, 4840000.000) ( 9d 7'26.87"E, 43d42'46.65"N)
Upper Right ( 750000.000, 5000000.000) ( 12d10'40.88"E, 45d 6'33.26"N)
Lower Right ( 750000.000, 4840000.000) ( 12d 6' 3.79"E, 43d40'15.39"N)
Center ( 630000.000, 4920000.000) ( 10d37'59.07"E, 44d25'17.84"N)
Band 1 Block=96000x1 Type=Byte, ColorInterp=Red
Overviews: 48000x32000, 24000x16000, 12000x8000, 6000x4000,
3000x2000, 1500x1000, 750x500, 375x250
Band 2 Block=96000x1 Type=Byte, ColorInterp=Green
Band 3 Block=96000x1 Type=Byte, ColorInterp=Blue
Driver: GTiff/GeoTIFF
Files: /media/Dati/Documenti/gps tuner/Altimetrie Italia/Emilia
Romagna/Emilia_Romagna.tif
Size is 4074, 4262
PROJCS["WGS 84 / UTM zone 32N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32632"]]
Origin = (499966.037957447464578,5101878.644408876076341)
Pixel Size = (80.031641738007920,-80.031641738007920)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=DEFLATE
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 499966.038, 5101878.644) ( 8d59'58.42"E, 46d 4'13.74"N)
Lower Left ( 499966.038, 4760783.787) ( 8d59'58.50"E, 42d59'58.99"N)
Upper Right ( 826014.946, 5101878.644) ( 13d12'35.68"E, 45d59'34.36"N)
Lower Right ( 826014.946, 4760783.787) ( 12d59'42.00"E, 42d55'47.82"N)
Center ( 662990.492, 4931331.216) ( 11d 3' 3.01"E, 44d31' 0.81"N)
Band 1 Block=256x256 Type=Int16, ColorInterp=Gray
Thank you for your help,
Corrado
