[gdal-dev] get GCP from noaa L1b
Andrew Brooks
arb at sat.dundee.ac.uk
Wed Jun 15 10:08:05 EDT 2011
Hi
>From memory the l1b driver doesn't use enough points to get proper
geolocation because it sub-samples the 51 which are provided in the l1b
file. The best solution (that recommended by NOAA) is to use lagrange
interpolation across the 51 points. A lagrange algorithm has been provided
in the ticket you referenced but nobody has added it to gdal. I think at the
moment you could consider the l1b driver broken.
Andrew
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110615/c9f14111/attachment.html
