[gdal-dev] get GCP from noaa L1b
Ramiro Gonzalez
ramirogonzalez at suremptec.com.ar
Fri Jun 17 10:55:39 EDT 2011
Function ProcessRecordHeaders in "formats/l1b/l1bdataset.cpp" subsamples the
GCPs of the l1b image, but the points are unordered an not equidistant.
I attached to TCK 2403 a patch that modifies this behaviour. I tested the
image attached to the ticket and seems to work ok(no error produced).
I also test the patched driver with an image of Argentina and worked ok.
I'd like to know if I misunderstood the intention of the code and the points
in each line shouldn't be equidistant.
Thanks
Ramiro
2011/6/15 Andrew Brooks <arb at sat.dundee.ac.uk>
> Hi
> From memory the l1b driver doesn't use enough points to get proper
> geolocation because it sub-samples the 51 which are provided in the l1b
> file. The best solution (that recommended by NOAA) is to use lagrange
> interpolation across the 51 points. A lagrange algorithm has been provided
> in the ticket you referenced but nobody has added it to gdal. I think at the
> moment you could consider the l1b driver broken.
> Andrew
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110617/b76515d2/attachment.html
