[gdal-dev] Problem Compiling with Oracle (--with-oci)
Nikolaos Hatzopoulos
nhatzop at gmail.com
Mon Jun 20 20:35:27 EDT 2011
check the configure file it might need changes (vi configure)
you can add the elgis repo add the devel package and start getting involved
with
the compile.
this is a src rpm:
http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/gdal-1.8.0-2.el5.elgis.src.rpm
if you are familiar with spec files I strongly suggest you to do it that way
--Nikos Hatzopoulos
On Mon, Jun 20, 2011 at 4:49 PM, Chris Hodgson <chodgson at refractions.net>wrote:
> grep tells me that the /ade/smayer.../ path is not in any text file in my
> gdal distribution (even after configuring) - which I grabbed the latest
> 1.8.0 from osgeo.org.
> Chris
> Ivan Lucena wrote:
>> Chris,
>> I am not on my Linux machine now to confirm but I would never needed to
>> use --with-expat pointing to Oracle's path. It is fanny that you found that
>> smaver path. Sounds like you got a tar.gz package from someone, not from a
>> GDAL distribution.
>> The OCI driver should not depend in nothing but OCI apart from GDAL/OGR
>> stuff.
>> Regards,
>> Ivan
>>> -------Original Message-------
>>> From: Chris Hodgson <chodgson at refractions.net>
>>> To: gdal-dev at lists.osgeo.org
>>> Subject: [gdal-dev] Problem Compiling with Oracle (--with-oci)
>>> Sent: Jun 20 '11 17:43
>>> I'm trying to compile GDAL/OGR with support for Oracle/OCI. I have the
>>> full oracle 11g server installed on CentOS 5.3.
>>> # configure --with-oci=/opt/oracle/**product/11.2.0/dbhome_1/
>>> # make
>>> libtool:.....
>>> g++: /ade/smayer_perl_510/perl_**source/expat_home/lib/**libexpat.so:
>>> No
>>> such file or directory
>>> I think this path might be from the person who compiled the OCI
>>> libraries for oracle 11? I have nothing remotely like it on my system.
>>> If I add --with-expat=no to my configure line I get errors during
>>> linking about undefined references to XML_... so I'm guessing the linked
>>> OCI drivers need the expat lib linked in.
>>> I added /opt/oracle/product/11.2.0/**dbhome_1/lib to my
>>> LD_LIBRARY_PATH,
>>> and there is a libexpat.so.1.5.2 there, as well as my
>>> /lib/libexpat.so.0.5.0 which is from my CentOS standarad RPMS:
>>> # rpm -qa | grep expat
>>> expat-1.95.8-8.2.1
>>> expat-devel-1.95.8-8.2.1
>>> I also tried --with-expat=/opt/oracle/**product/11.2.0/dbhome_1/ but
>>> there
>>> are no headers there, among other problems.
>>> How can I get this to work?
>>> Thanks,
>>> Chris
>>> ______________________________**_________________
>>> gdal-dev mailing list
>>> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110620/75297528/attachment-0001.html
