[gdal-dev] Problem Compiling with Oracle (--with-oci)
Chris Hodgson
chodgson at refractions.net
Tue Jun 21 13:38:48 EDT 2011
What would need changed in the configure file? There is no reference
there to the non-existent libexpat.
I'm not familiar with spec files... but if I wanted to learn - what
could I do there that I couldn't do in the configure/make process? The
spec file still uses the package's build system right?
It's not until the final linking with libtool that the problem happens,
I just don't know what I need to tell libtool to get it to smarten up...
Surely other people have compiled with support for oracle 11g? CentOS is
just repackaged RHEL.... I don't know what I'm doing that is out of the
ordinary here.
Chris
Nikolaos Hatzopoulos wrote:
> check the configure file it might need changes (vi configure)
> you can add the elgis repo add the devel package and start getting
> involved with
> the compile.
> this is a src rpm:
> http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/gdal-1.8.0-2.el5.elgis.src.rpm
> if you are familiar with spec files I strongly suggest you to do it
> that way :)
> --Nikos Hatzopoulos
> On Mon, Jun 20, 2011 at 4:49 PM, Chris Hodgson
> <chodgson at refractions.net <mailto:chodgson at refractions.net>> wrote:
> grep tells me that the /ade/smayer.../ path is not in any text
> file in my gdal distribution (even after configuring) - which I
> grabbed the latest 1.8.0 from osgeo.org <http://osgeo.org>.
> Chris
> Ivan Lucena wrote:
> Chris,
> I am not on my Linux machine now to confirm but I would never
> needed to use --with-expat pointing to Oracle's path. It is
> fanny that you found that smaver path. Sounds like you got a
> tar.gz package from someone, not from a GDAL distribution.
> The OCI driver should not depend in nothing but OCI apart from
> GDAL/OGR stuff.
> Regards,
> Ivan
> -------Original Message-------
> From: Chris Hodgson <chodgson at refractions.net
> To: gdal-dev at lists.osgeo.org
> <mailto:gdal-dev at lists.osgeo.org>
> Subject: [gdal-dev] Problem Compiling with Oracle
> (--with-oci)
> Sent: Jun 20 '11 17:43
> I'm trying to compile GDAL/OGR with support for
> Oracle/OCI. I have the
> full oracle 11g server installed on CentOS 5.3.
> # configure --with-oci=/opt/oracle/product/11.2.0/dbhome_1/
> # make
> libtool:.....
> g++:
> /ade/smayer_perl_510/perl_source/expat_home/lib/libexpat.so:
> No
> such file or directory
> I think this path might be from the person who compiled
> the OCI
> libraries for oracle 11? I have nothing remotely like it
> on my system.
> If I add --with-expat=no to my configure line I get
> errors during
> linking about undefined references to XML_... so I'm
> guessing the linked
> OCI drivers need the expat lib linked in.
> I added /opt/oracle/product/11.2.0/dbhome_1/lib to my
> LD_LIBRARY_PATH,
> and there is a libexpat.so.1.5.2 there, as well as my
> /lib/libexpat.so.0.5.0 which is from my CentOS standarad
> RPMS:
> # rpm -qa | grep expat
> expat-1.95.8-8.2.1
> expat-devel-1.95.8-8.2.1
> I also tried
> --with-expat=/opt/oracle/product/11.2.0/dbhome_1/ but there
> are no headers there, among other problems.
> How can I get this to work?
> Thanks,
> Chris
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
