[gdal-dev] Problem Compiling with Oracle (--with-oci)
Smith, Michael D ERDC-CRREL-NH
michael.smith at usace.army.mil
Tue Jun 21 15:21:43 EDT 2011
I have the expat 1.95 added via standed RHEL repo and using oracle instant
client (11.2) without a problem with GDAL from SVN
I use
./configure \
--with-libtiff=internal \
--with-geotiff=internal \
--with-jpeg=internal \
--with-libz=internal \
--with-png=internal \
--with-oci=/oracle/instantclient_11_1 \
--with-geos=/usr/local/bin/geos-config \
--with-curl \
--with-threads \
--with-expat=yes \
--with-libkml \
--with-python
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
Hanover, NH
On 6/21/11 3:15 PM, "Nikolaos Hatzopoulos" <nhatzop at gmail.com> wrote:
> vi configure :)
> --Nikos
> On Tue, Jun 21, 2011 at 12:02 PM, Chris Hodgson <chodgson at refractions.net>
> wrote:
>> Ivan I appreciate your help here, but I think I've already tried everything
>> you are suggesting. I dont' have an ORACLE_HOME set on the user doing this
>> compiling, so if I don't specify --with-oci=... I don't get oracle support. I
>> do have expat 1.95 installed (with -devel package as well) and it is
>> automatically picked up by configure.
>> I can build gdal successfully with no configure options, it builds with expat
>> support among other defaults.
>> If I specify --with-oci, I get the error about the funny libexpat path, if I
>> add --with-expat=no, I get past that error, but get an error later when it
>> can't find the XML_* symbols that the oracle library needs to be linked to.
>> In neither of these cases to i get a working version of gdalinfo built.
>> It seems to me that I need to link in expat for the oracle library, but I'm
>> not sure if it is compatible with the 1.95 version the my system has
>> installed and that GDAL requires if I specify --with-expat ... because there
>> is an libexpat.so.0.5 in the oracle lib directory. Since I don't actually
>> need GDAL's expat support, I'm fine with --with-expat=no ... but then I need
>> to somehow tell libtool to ignore the funny expat path it is finding and use
>> the expat in the oracle directory... perhaps the best way to do this is just
>> to copy the libtool command that is failing in the build and tweak it
>> manually to have the right path to the oracle expat instead of the funny
>> path... however I won't be able to get to the next step of the build to see
>> what other commands I need to run... is there a way to modify the makefile or
>> tell configure about this?
>> Thanks,
>> Chris
>> Ivan Lucena wrote:
>>> Hi Chris,
>>> I would not advise changing the configuration file.
>>> If you have a full installation of Oracle in your system you probably have a
>>> ORACLE_HOME environment variable, so if you run:
>>> $ ./configure
>>> checking for Oracle OCI headers in /oracle/path/... yes
>>> checking for Oracle OCI libraries in /oracle/path/lib... yes
>>> checking if Oracle OCI version is >= 8.1.7 ... yes
>>> checking for Oracle version >= 10.x to use -lnnz10 flag... yes
>>> checking if Oracle support is enabled... yes
>>> OCI support: yes
>>> GEORASTER support: yes
>>> If you don't have ORACLE_HOME you can pass the path using
>>> $ ./configure --with-oci=/oracle/path/...
>>> Now, you system is CentOS and I have never build GDAL on it but I would
>>> guess that it doesn't have Expat installed yet. My Linux does, so configure
>>> finds it:
>>> checking for XML_ParserCreate in -lexpat... yes
>>> checking for Expat XML Parser headers in /usr/include... found
>>> checking for Expat XML Parser... yes
>>> My suggestion is to isolate the problem by running ./configure, make and
>>> gdalinfo without Expat once and then make clean, ./configure, make and
>>> gdalinfo without OCI, ex:
>>> % ./configure --with-expat=NO % ./configure --with-OCI=NO
>>> Configure will setup your makefiles, then you run make based on those new
>>> settings.
>>> Good luck.
>>> Ivan
>>>> -------Original Message-------
>>>> From: Chris Hodgson <chodgson at refractions.net>
>>>> To: gdal-dev at lists.osgeo.org
>>>> Subject: Re: [gdal-dev] Problem Compiling with Oracle (--with-oci)
>>>> Sent: Jun 21 '11 12:38
>>>> What would need changed in the configure file? There is no reference
>>>> there to the non-existent libexpat.
>>>> I'm not familiar with spec files... but if I wanted to learn - what
>>>> could I do there that I couldn't do in the configure/make process? The
>>>> spec file still uses the package's build system right?
>>>> It's not until the final linking with libtool that the problem happens,
>>>> I just don't know what I need to tell libtool to get it to smarten up...
>>>> Surely other people have compiled with support for oracle 11g? CentOS is
>>>> just repackaged RHEL.... I don't know what I'm doing that is out of the
>>>> ordinary here.
>>>> Chris
>>>> Nikolaos Hatzopoulos wrote:
>>>> > check the configure file it might need changes (vi configure)
>>>> > you can add the elgis repo add the devel package and start getting
>>>> > involved with
>>>> > the compile.
>>>> > this is a src rpm:
>>>> http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/gdal-1.8.0-2.el5.elgis.s
>>>> rc.rpm
>>>> <http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/gdal-1.8.0-2.el5.elgis.
>>>> src.rpm>
>>>> > if you are familiar with spec files I strongly suggest you to do it
>>>> > that way :)
>>>> > --Nikos Hatzopoulos
>>>> > On Mon, Jun 20, 2011 at 4:49 PM, Chris Hodgson
>>>> > <chodgson at refractions.net <mailto:chodgson at refractions.net
>>>> <mailto:chodgson at refractions.net> >> wrote:
>>>> > grep tells me that the /ade/smayer.../ path is not in any text
>>>> > file in my gdal distribution (even after configuring) - which I
>>>> > grabbed the latest 1.8.0 from osgeo.org <http://osgeo.org>
>>>> <http://osgeo.org>.
>>>> > Chris
>>>> > Ivan Lucena wrote:
>>>> > Chris,
>>>> > I am not on my Linux machine now to confirm but I would never
>>>> > needed to use --with-expat pointing to Oracle's path. It is
>>>> > fanny that you found that smaver path. Sounds like you got a
>>>> > tar.gz package from someone, not from a GDAL distribution.
>>>> > The OCI driver should not depend in nothing but OCI apart from
>>>> > GDAL/OGR stuff.
>>>> > Regards,
>>>> > Ivan
>>>> > <mailto:gdal-dev at lists.osgeo.org
>>>> <mailto:gdal-dev at lists.osgeo.org> >
>>>> > Subject: [gdal-dev] Problem Compiling with Oracle
>>>> > (--with-oci)
>>>> > Sent: Jun 20 '11 17:43
>>>> > I'm trying to compile GDAL/OGR with support for
>>>> > Oracle/OCI. I have the
>>>> > full oracle 11g server installed on CentOS 5.3.
>>>> > # configure --with-oci=/opt/oracle/product/11.2.0/dbhome_1/
>>>> > # make
>>>> > libtool:.....
>>>> > g++:
>>>> > /ade/smayer_perl_510/perl_source/expat_home/lib/libexpat.so:
>>>> > No
>>>> > such file or directory
>>>> > I think this path might be from the person who compiled
>>>> > the OCI
>>>> > libraries for oracle 11? I have nothing remotely like it
>>>> > on my system.
>>>> > If I add --with-expat=no to my configure line I get
>>>> > errors during
>>>> > linking about undefined references to XML_... so I'm
>>>> > guessing the linked
>>>> > OCI drivers need the expat lib linked in.
>>>> > I added /opt/oracle/product/11.2.0/dbhome_1/lib to my
>>>> > LD_LIBRARY_PATH,
>>>> > and there is a libexpat.so.1.5.2 there, as well as my
>>>> > /lib/libexpat.so.0.5.0 which is from my CentOS standarad
>>>> > RPMS:
>>>> > # rpm -qa | grep expat
>>>> > expat-1.95.8-8.2.1
>>>> > expat-devel-1.95.8-8.2.1
>>>> > I also tried
>>>> > --with-expat=/opt/oracle/product/11.2.0/dbhome_1/ but there
>>>> > are no headers there, among other problems.
>>>> > How can I get this to work?
>>>> > Thanks,
>>>> > Chris
>>>> > _______________________________________________
>>>> > gdal-dev mailing list
>>>> > gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org
>>>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110621/0a5d83d6/attachment-0001.html
