[gdal-dev] Re: Is it possible for gdal_translate to perserve the
external georeferencing information?
Frank Warmerdam
warmerdam at pobox.com
Wed Jun 22 23:05:59 EDT 2011
On 11-06-22 10:54 PM, conant wrote:
> Thank you Frank!
> Here it is the xml file. Yes, it seems that gdalinfo detected the xml file
> but it did not read it. Any suggestion?
> Cheers,
> Nuo
> <?xml version="1.0" encoding="utf-8" ?>
> -<GeodataXform xsi:type="typens:PolynomialXform"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:typens="http://www.esri.com/schemas/ArcGIS/9.3">
Nuo,
The above file is not a GDAL .aux.xml file. Is that really the extension
it had? I'm not sure what version of ArcGIS produces such a file (well
presumably 9.3 based on the schema) but there is nothing that GDAL can do
with it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
