[gdal-dev] Re: Is it possible for gdal_translate to perserve the
external georeferencing information?
Nuo
conan_tang at hotmail.com
Sun Jun 26 06:51:34 EDT 2011
Frank, I really appreciate your reply.
I thought it was but, actually, it is a ".aux.xml" file generated by ArcGIS
9.3.1 during the georeferencing process.
http://webhelp.esri.com/arcgiSDEsktop/9.3/index.cfm?TopicName=About_auxiliary_files
So, it is impossible to preserve the georeference information- I have to
either:
rectify the image (save a new geotiff file) and gdal_translate to jp2; or
gdal_translate to jp2 and then re-georeference it.
Is that right? Thank you again.
Regards,
Nuo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-Is-it-possible-for-gdal-translate-to-perserve-the-external-georeferencing-information-tp6498773p6516947.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
