[gdal-dev] Re: Is it possible for gdal_translate to perserve the
external georeferencing information?
Frank Warmerdam
warmerdam at pobox.com
Sun Jun 26 07:39:44 EDT 2011
On 11-06-26 06:51 AM, Nuo wrote:
> Frank, I really appreciate your reply.
> I thought it was but, actually, it is a ".aux.xml" file generated by ArcGIS
> 9.3.1 during the georeferencing process.
> http://webhelp.esri.com/arcgiSDEsktop/9.3/index.cfm?TopicName=About_auxiliary_files
> So, it is impossible to preserve the georeference information- I have to
> either:
> rectify the image (save a new geotiff file) and gdal_translate to jp2; or
> gdal_translate to jp2 and then re-georeference it.
> Is that right? Thank you again.
Nuo,
*GDAL* can't preserve that georeferencing. You might find you can
do a gdal_translate to the new file and then just rename the .aux.xml
file or something like that. But it is outside my area of knowledge.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
