[gdal-dev] JAXAPalsar 1.0 & 1.1 extended metadata reading support
Rodolfo Bonnin
rodolfobonnin at suremptec.com.ar
Thu Jun 23 09:56:21 EDT 2011
I have another doubt regarding the adfGeoTransform to be employed. The
JaxaPalsar has 8 coefficients to represent the mapping between
pixel-line and the map projection frame of reference ( It includes de
P L factor for X and Y, and gdal doesn't I think ). What should If the
PL factor is not near 0? Should I generate additional control points?
Thanks for your help.
Regards,
Rodolfo.
2011/6/20 Frank Warmerdam <warmerdam at pobox.com>:
> On 11-06-18 12:59 PM, Antonio Valentino wrote:
>> Regarding the JAXAPalsar driver, it is currently registered *after* the
>> ceos2 driver so, if my understanding is correct, CEOS products should be
>> opened with ceos2 and the JAXAPalsar should be used as a fallback.
>> Is it correct?
> Antonio,
> Yes, if it is registered after the SAR_CEOS driver (frmts/ceos2) then it
> would only be used for datasets not recgonised by the SAR_CEOS driver.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Ing. Rodolfo Bonnin
SUR Emprendimientos Tecnológicos
Perú 345 Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
www.suremptec.com
