[gdal-dev] JAXAPalsar 1.0 & 1.1 extended metadata reading support
Rodolfo Bonnin rodolfobonnin at suremptec.com.ar
Wed Jun 22 13:26:47 EDT 2011
Thanks Antonio,
I've detected a way to at least read the UTM zone of the product, and
will be back once I can get more data from the files, so we can think
more carefully where the changes belong. Many thanks again.
2011/6/18 Antonio Valentino <antonio.valentino at tiscali.it>:
> Hi Frank,
> Il 18/06/2011 14:38, Frank Warmerdam ha scritto:
>> On 11-06-18 02:59 AM, Antonio Valentino wrote:
>>> I don't know if someone is currently working on the JAXAPalsar driver.
>>> Anyway I' very interested in extending driver for SAR products to get
>>> more metadata so I would be happy to help if you need.
>> Folks,
>> Phil Vachon did most of the JAXA Palsar work but has moved on to
>> non-geospatial pursuits, so anyone interested should feel free to
>> dig in.
>>> Palsar products are in CEOS format so IMHO it would be nice to setup a
>>> general mechanism to decode CEOS records (a similar job has been done
>>> for ENVISAT records recently)
>>> http://trac.osgeo.org/gdal/ticket/4105
>>> http://trac.osgeo.org/gdal/attachment/ticket/4105/asar_metadata.patch
>>> The hard part (it is a very boring job) IMHO is to fill data structures
>>> that properly describe CEOS records for each sensor end product type.
>>> Anyway populating record descriptors is a job that can be done gradually
>>> and, hopefully, with the help of other users so we could start with the
>>> few metadata you are currently interested in and add other record
>>> descriptors later.
>>> The key is to setup a genereal (enough) framework for CEOS record
>>> decoding.
>> There is already a generic SAR CEOS driver (gdal/frmts/ceos2) with a CEOS
>> record parsing mechanism.  If that is what you want, please start from it.
>> For reasons not immediately obvious to me Phil chose to build a specific
>> JAXA Palsar driver but please think twice before building it out into a
>> full
>> generic CEOS driver duplicating what already exists.
> Thank you Frank.
> My basic idea was to propose an improvement of the ceos2 driver but I
> completely missed GetCeosField function. Sorry.
> Looking better to the code it seems that all tools for record decoding
> are already there, as you pointed out, so it is just a matter of getting
> more metadata.
> Regarding the JAXAPalsar driver, it is currently registered *after* the
> ceos2 driver so, if my understanding is correct, CEOS products should be
> opened with ceos2 and the JAXAPalsar should be used as a fallback.
> Is it correct?
> Any way I'm currently downloading some sample PALSAR product to see what
> happens.
> Best regards
> Antonio Valentino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Ing. Rodolfo Bonnin
SUR Emprendimientos Tecnológicos
Perú 345  Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
www.suremptec.com
