[gdal-dev] JAXAPalsar 1.0 & 1.1 extended metadata reading support
Rodolfo Bonnin rodolfobonnin at suremptec.com.ar
Wed Jun 22 16:31:30 EDT 2011
Hello Antonio, Frank,
I've now been able to read the false northing UTM parameter. The next
step is the coordinate system, which is ITRF 97. As this is not a well
known coordinate system, could this definition be enough to represent
the standard? (from spatialreference.org):
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _  _ _ _ _ _ _ _ _ _ _ _ _
GEOCCS["ITRF97",
    DATUM["International Terrestrial Reference Frame 1997",
        SPHEROID["GRS 1980",6378137.0,298.257222101,
            AUTHORITY["EPSG","7019"]],
        AUTHORITY["EPSG","6655"]],
    PRIMEM["Greenwich",0.0,
        AUTHORITY["EPSG","8901"]],
    UNIT["m",1.0],
    AXIS["Geocentric X",OTHER],
    AXIS["Geocentric Y",EAST],
    AXIS["Geocentric Z",NORTH],
    AUTHORITY["EPSG","4918"]]
Many thanks in advance.
Best Regards,
Ing. Rodolfo Bonnin
2011/6/22 Rodolfo Bonnin <rodolfobonnin at suremptec.com.ar>:
> Thanks Antonio,
> I've detected a way to at least read the UTM zone of the product, and
> will be back once I can get more data from the files, so we can think
> more carefully where the changes belong. Many thanks again.
> 2011/6/18 Antonio Valentino <antonio.valentino at tiscali.it>:
>> Hi Frank,
>> Il 18/06/2011 14:38, Frank Warmerdam ha scritto:
>>> On 11-06-18 02:59 AM, Antonio Valentino wrote:
>>>> I don't know if someone is currently working on the JAXAPalsar driver.
>>>> Anyway I' very interested in extending driver for SAR products to get
>>>> more metadata so I would be happy to help if you need.
>>> Folks,
>>> Phil Vachon did most of the JAXA Palsar work but has moved on to
>>> non-geospatial pursuits, so anyone interested should feel free to
>>> dig in.
>>>> Palsar products are in CEOS format so IMHO it would be nice to setup a
>>>> general mechanism to decode CEOS records (a similar job has been done
>>>> for ENVISAT records recently)
>>>> http://trac.osgeo.org/gdal/ticket/4105
>>>> http://trac.osgeo.org/gdal/attachment/ticket/4105/asar_metadata.patch
>>>> The hard part (it is a very boring job) IMHO is to fill data structures
>>>> that properly describe CEOS records for each sensor end product type.
>>>> Anyway populating record descriptors is a job that can be done gradually
>>>> and, hopefully, with the help of other users so we could start with the
>>>> few metadata you are currently interested in and add other record
>>>> descriptors later.
>>>> The key is to setup a genereal (enough) framework for CEOS record
>>>> decoding.
>>> There is already a generic SAR CEOS driver (gdal/frmts/ceos2) with a CEOS
>>> record parsing mechanism.  If that is what you want, please start from it.
>>> For reasons not immediately obvious to me Phil chose to build a specific
>>> JAXA Palsar driver but please think twice before building it out into a
>>> full
>>> generic CEOS driver duplicating what already exists.
>> Thank you Frank.
>> My basic idea was to propose an improvement of the ceos2 driver but I
>> completely missed GetCeosField function. Sorry.
>> Looking better to the code it seems that all tools for record decoding
>> are already there, as you pointed out, so it is just a matter of getting
>> more metadata.
>> Regarding the JAXAPalsar driver, it is currently registered *after* the
>> ceos2 driver so, if my understanding is correct, CEOS products should be
>> opened with ceos2 and the JAXAPalsar should be used as a fallback.
>> Is it correct?
>> Any way I'm currently downloading some sample PALSAR product to see what
>> happens.
>> Best regards
>> Antonio Valentino
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Ing. Rodolfo Bonnin
> SUR Emprendimientos Tecnológicos
> Perú 345  Piso 5to Oficina "B" (C1067AAG)
> Ciudad de Buenos Aires, Argentina
> Tel. +54 (11) 4342-2976/84
> www.suremptec.com
Ing. Rodolfo Bonnin
www.suremptec.com
