[gdal-dev] JAXAPalsar 1.0 & 1.1 extended metadata reading support
Frank Warmerdam
warmerdam at pobox.com
Thu Jun 23 13:11:28 EDT 2011
On 11-06-22 04:31 PM, Rodolfo Bonnin wrote:
> Hello Antonio, Frank,
> I've now been able to read the false northing UTM parameter. The next
> step is the coordinate system, which is ITRF 97. As this is not a well
> known coordinate system, could this definition be enough to represent
> the standard? (from spatialreference.org):
> _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
> GEOCCS["ITRF97",
> DATUM["International Terrestrial Reference Frame 1997",
> SPHEROID["GRS 1980",6378137.0,298.257222101,
> AUTHORITY["EPSG","7019"]],
> AUTHORITY["EPSG","6655"]],
> PRIMEM["Greenwich",0.0,
> AUTHORITY["EPSG","8901"]],
> UNIT["m",1.0],
> AXIS["Geocentric X",OTHER],
> AXIS["Geocentric Y",EAST],
> AXIS["Geocentric Z",NORTH],
> AUTHORITY["EPSG","4918"]]
Rondolfo,
In GDAL trunk I have added support for geocentric coordinate systems and
the expansion of EPSG:4338 looks like:
GEOCCS["ITRF97 (geocentric)",
DATUM["International_Terrestrial_Reference_Frame_1997",
SPHEROID["GRS 1980",6378137,298.257222101,
PRIMEM["Greenwich",0,
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Geocentric Y",OTHER],
AUTHORITY["EPSG","4338"]]
I believe yours if functionally equivelent. Note that GDAL is unlikely
to support geocentric coordinate systems in a useful fashion in 1.8 and
earlier versions.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
