[gdal-dev] How to apply a costum shift grid?
Joaquim Luis
jluis at ualg.pt
Tue Jun 28 12:15:54 EDT 2011
Frederick,
I'm a geophysicist but never thought that an earthquake could have that
side effect of image referencing.
Anyway the horizontal deformation caused by a big earthquake is of the
order of meter scale. One idea I had is that you can use the shift grid
to to relocate previous GCPs and than use those relocated ones in
gdalwarp. You can compute 'old' GCPs by interpolating your images both
for pixels and metric (UTM) units. The operations would be something
like this
1. Get "px py old_UTMx old_UTMy" by interpolating the referenced image
at a certain well distributed positions
2. apply the shift grid to old GCPs and get new GCPs "px py new_UTMx
new_UTMy"
2. re-register with gdalwarp and new GCPs
Of course, this is in absence of a more straight solution where the
shift grid is applied directly to the images.
Joaquim Luis
> Hi,
> I am working here in Chile and we have a lot of earthquakes here, the last
> big one like a year ago. So the problem is that I have a lot of
> georeferenced images, but georeferenced before the earthquake. We thought
> the best way would be to calculate a shift grid and apply it with gdalwarp
> to all of the images. The only thing I would have to do is to apply the grid
> from one datum to the same datum instead of from one datum to another, this
> should be possible, shouldn´t it?
> Reading a lot in the mailing-list I found a link to an australian
> govermental site, where they provide a program to convert from NTv2_ASCII to
> NTv2_GSB. So I created an Ntv2_ASCII file with our shift values and
> converted it with this program to an .gsb-file and tried to apply that file
> with gdalwarp to our images. But no matter what I tried, nothing happened,
> the shift never was applied. I saw a lot of examples of possible commands
> searching in the mailing-list and tried everyone, also in nearly every
> possible combination but nothing lead to an applied shift. So I am a bit
> desperate right now, hoping someone can help me a bit or give an advice.
> Here in short what I have to do:
> Apply a shift grid from UTM 18s WGS84 to UTM 18s WGS84 in order to apply the
> coordinate changes of our images owing of the earthquake last year.
> I would apreciate any kind of help and thank a lot in advance,
> Frederick
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-apply-a-costum-shift-grid-tp6524901p6524901.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
