[gdal-dev] [GDAL_TRANSLATE] Gray scale
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Thu Jun 30 10:01:25 EDT 2011
Hi Solimyr,
could you run a "gdalinfo -stats" on your input GTiff to let us better
understand the characteristics of the image to be converted?
Regards,
Daniele
On Thu, Jun 30, 2011 at 3:31 PM, Gianni Cristian <giannicristian at msn.com>wrote:
> Hi guys,
> I need to convert an image from GTiff to ENVI format. I want also that my
> image is in Grayscale. The GTiff image have just one band. If I do with
> ENVI, I save the file as Image, ENVI 8-bit (I call this results fromENVI).
> When I try to do the same with gdal_translate I do:
> gdal_translate -of ENVI -ot Byte gtiffimg.tif fromgdal.raw
> But the result is a lot different from the 'fromENVI' image. So I have
> tried
> to do:
> gdal_translate -of ENVI -ot Byte -b 1 -expand gray gtiffimg.tif
> fromgdal.raw
> and
> gdal_translate -of ENVI -ot Byte -expand gray gtiffimg.tif fromgdal.raw
> But I get the following error:
> Input file size is 1828, 1646
> Error : band 1 has no color table
> I wrong something or is gdal fault?
> Thx
> Solimyr
> http://osgeo-org.1803224.n2.nabble.com/GDAL-TRANSLATE-Gray-scale-tp6533237p6533237.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Ing. Daniele Romagnoli
GeoSolutions S.A.S.
Software Engineer
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 962313
http://www.geo-solutions.it
http://geo-solutions.blogspot.com/
http://www.youtube.com/user/GeoSolutionsIT
http://it.linkedin.com/in/danieleromagnoli
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110630/7008ed6b/attachment.html
