[gdal-dev] Re: [GDAL_TRANSLATE] Gray scale
Solimyr
giannicristian at msn.com
Thu Jun 30 10:11:36 EDT 2011
Driver: GTiff/GeoTIFF
Files: File.tif
File.tfw
Size is 1828, 1646
Coordinate System is:
PROJCS["WGS 84 / UTM zone 47S",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",99],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32747"]]
Origin = (650301.875000000000000,9895384.375000000000000)
Pixel Size = (1.250000000000000,-1.250000000000000)
Metadata:
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 650301.875, 9895384.375) (100d21' 2.82"E, 0d56'46.41"S)
Lower Left ( 650301.875, 9893326.875) (100d21' 2.84"E, 0d57'53.40"S)
Upper Right ( 652586.875, 9895384.375) (100d22'16.73"E, 0d56'46.38"S)
Lower Right ( 652586.875, 9893326.875) (100d22'16.76"E, 0d57'53.37"S)
Center ( 651444.375, 9894355.625) (100d21'39.79"E, 0d57'19.89"S)
Band 1 Block=1828x1 Type=UInt16, ColorInterp=Gray
Minimum=1.000, Maximum=24806.000, Mean=230.385, StdDev=290.366
Metadata:
STATISTICS_MINIMUM=1
STATISTICS_MAXIMUM=24806
STATISTICS_MEAN=230.38520376963
STATISTICS_STDDEV=290.36594272901
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-TRANSLATE-Gray-scale-tp6533237p6533400.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
