[gdal-dev] Strange issue on debian squeeze
Stephen Woodbridge woodbri at swoodbridge.com
Tue Mar 15 15:15:02 EDT 2011
On 3/15/2011 2:23 PM, Chaitanya kumar CH wrote:
> Oliver,
> Can you confirm if you have xerces headers in /etc/include directory?
That should probably say /usr/include directory, in case that was not
obvious.
-Steve
> On Tue, Mar 15, 2011 at 11:13 PM, Oliver Burger
> <oliver.bgr at googlemail.com <mailto:oliver.bgr at googlemail.com>> wrote:
>     I have a strange problem installing gdal-1.8.0 on a debian squeeze 64bit
>     server.
>     I'm using the following configure:
>     ./configure --prefix=/usr/local/gdal-1.8.0 --with-xerces=yes
>     Installed are:
>     libxerces-c-dev             3.1.1-1+b1
>     libxerces-c3.1              3.1.1-1+b1
>     out of the debian repositories.
>     And I'm getting the following output from configure:
>     checking for Xerces C++ Parser headers in /usr/include and
>     /usr/include/xercesc... not found
>     checking for Xerces C++ Parser... no
>     Xerces-C support:          no
>     The same happens e.g. with expat and openjpeg.
>     It's working all right on a Ubuntu 32bit and a Mandriva 32bit machine.
>     Do you have any idea, what is happening here?
>     Thanks,
>     Oliver
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
