[gdal-dev] Strange issue on debian squeeze
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Mar 15 14:23:45 EDT 2011
Oliver,
Can you confirm if you have xerces headers in /etc/include directory?
On Tue, Mar 15, 2011 at 11:13 PM, Oliver Burger
<oliver.bgr at googlemail.com>wrote:
> I have a strange problem installing gdal-1.8.0 on a debian squeeze 64bit
> server.
> I'm using the following configure:
> ./configure --prefix=/usr/local/gdal-1.8.0 --with-xerces=yes
> Installed are:
> libxerces-c-dev             3.1.1-1+b1
> libxerces-c3.1              3.1.1-1+b1
> out of the debian repositories.
> And I'm getting the following output from configure:
> checking for Xerces C++ Parser headers in /usr/include and
> /usr/include/xercesc... not found
> checking for Xerces C++ Parser... no
> Xerces-C support:          no
> The same happens e.g. with expat and openjpeg.
> It's working all right on a Ubuntu 32bit and a Mandriva 32bit machine.
> Do you have any idea, what is happening here?
> Thanks,
> Oliver
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110315/c2b7b108/attachment.html
