[gdal-dev] Strange issue on debian squeeze
Oliver Burger oliver.bgr at googlemail.com
Tue Mar 15 13:43:40 EDT 2011
I have a strange problem installing gdal-1.8.0 on a debian squeeze 64bit
server.
I'm using the following configure:
./configure --prefix=/usr/local/gdal-1.8.0 --with-xerces=yes
Installed are:
libxerces-c-dev             3.1.1-1+b1
libxerces-c3.1              3.1.1-1+b1
out of the debian repositories.
And I'm getting the following output from configure:
checking for Xerces C++ Parser headers in /usr/include and
/usr/include/xercesc... not found
checking for Xerces C++ Parser... no
Xerces-C support:          no
The same happens e.g. with expat and openjpeg.
It's working all right on a Ubuntu 32bit and a Mandriva 32bit machine.
Do you have any idea, what is happening here?
Thanks,
Oliver
