[gdal-dev] Rotate unreferenced tiff file by -90 degrees
Wesley Roberts WRoberts at csir.co.za
Thu Mar 17 05:09:36 EDT 2011
Dear gdal'ers
I am working with TRMM rainfall data from an HDF5 file (converted from hdf4 to hdf5). I am able to use gdal_translate to extract the gridded data from the HDF file using the following command.
gdal_translate -of GTiff "HDF5:"3A25.071201.6A.h5"://DATA_GRANULE/PlanetaryGrid2/e_surfRainMean2" test.tif
Gdal_translate works a treat and writes out the test.tif file perfectly, however, the file is unreferenced and needs to be rotated by -90 degrees. Is it possible to do this using gdal_translate or do I need to make use of gdalwarp as well? My tiff world file needs to look something like this
       0.500000
        0.0000000
       0.0000000
      -0.500000
    -179.750000
      36.750000
Am I correct in assuming that a suitable proj4 statement might do the trick, wrt assigning projection info and defining rotation? If so can someone point me towards a document explaining the various proj4 declaration parameters, or give me some advice on how to go about getting the data properly referenced.
I can complete the task using ENVI but I would far rather write a bash script to get it all done in four or five lines of code.
Thanking you in advance
Wesley
Wesley Roberts PhD.
Researcher: Earth Observation
Natural Resources & the Environment (NRE)
CSIR
Tel: +27 (0)21 888-2490
Fax: +27 (0)21 888-2693
skype: roberts-w
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean.  MailScanner thanks Transtec Computers for their support.
