[gdal-dev] Rotate unreferenced tiff file by -90 degrees
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 17 09:34:24 EDT 2011
On 11-03-17 05:09 AM, Wesley Roberts wrote:
> Dear gdal'ers
> I am working with TRMM rainfall data from an HDF5 file (converted from hdf4
> to hdf5). I am able to use gdal_translate to extract the gridded data from
> the HDF file using the following command.
> gdal_translate -of GTiff
> "HDF5:"3A25.071201.6A.h5"://DATA_GRANULE/PlanetaryGrid2/e_surfRainMean2"
> test.tif
> Gdal_translate works a treat and writes out the test.tif file perfectly,
> however, the file is unreferenced and needs to be rotated by -90 degrees. Is
> it possible to do this using gdal_translate or do I need to make use of
> gdalwarp as well? My tiff world file needs to look something like this
> 0.500000 0.0000000 0.0000000 -0.500000 -179.750000 36.750000
> Am I correct in assuming that a suitable proj4 statement might do the trick,
> wrt assigning projection info and defining rotation? If so can someone point
> me towards a document explaining the various proj4 declaration parameters,
> or give me some advice on how to go about getting the data properly
> referenced.
Wesley,
I think the easiest approach is to prepare a worldfile representing the
current georeferencing in east-up or west-up orientation. Then use
gdalwarp to transform it to north up.
gdalwarp input.tif output.tif
For "east up" I think the world file might look something like:
0.0
0.5
0.5
0.0
top-left-x
top-left-y
You might need to fiddle around with the orientation a bit to get it
right.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
