[gdal-dev] openjpeg build configuration
Brian Wilson
brian at wildsong.biz
Thu Mar 17 11:36:24 EDT 2011
I am trying to build 1.8.0 on Linux with openjpeg support.
I can easily build and install openjpeg from source
(oropenjpeg_v1_4_sources_r697) into /usr/local
./configure --with-openjpeg
./configure --with-openjpeg=/usr/local
both result in
OpenJPEG support: no
I wiped my gdal-1.8.0 directory and unpacked a fresh copy to make sure
nothing was cached.
I can see this test in configure output
checking for opj_decode_tile_data in -lopenjpeg... no
which does not look promising. Is there a version compat problem?
Brian
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110317/ecd2c145/attachment.html
