[gdal-dev] openjpeg build configuration
Even Rouault
even.rouault at mines-paris.org
Thu Mar 17 12:23:18 EDT 2011
Selon Brian Wilson <brian at wildsong.biz>:
Please read carefully the first lines of http://gdal.org/frmt_jp2openjpeg.html
for the explanation (and solution)
> I am trying to build 1.8.0 on Linux with openjpeg support.
> I can easily build and install openjpeg from source
> (oropenjpeg_v1_4_sources_r697) into /usr/local
> ./configure --with-openjpeg
> ./configure --with-openjpeg=/usr/local
> both result in
> OpenJPEG support: no
> I wiped my gdal-1.8.0 directory and unpacked a fresh copy to make sure
> nothing was cached.
> I can see this test in configure output
> checking for opj_decode_tile_data in -lopenjpeg... no
> which does not look promising. Is there a version compat problem?
> Brian
