[gdal-dev] openjpeg build configuration
Julien Michel julien.michel at cnes.fr
Thu Mar 17 12:28:19 EDT 2011
I hop on the thread since I am interested in openjpeg support too. It
seems than those lines you pointed out are quite outdated, because
openjpeg 1.4 released january 2011 provides tile-level reading. Is there
any chance to build the gdal driver with openjpeg 1.4 ?
Many thanks for your help,
Best regards,
Julien Michel
Le 17/03/2011 17:23, Even Rouault a écrit :
> Selon Brian Wilson<brian at wildsong.biz>:
> Please read carefully the first lines of http://gdal.org/frmt_jp2openjpeg.html
> for the explanation (and solution)
>> I am trying to build 1.8.0 on Linux with openjpeg support.
>> I can easily build and install openjpeg from source
>> (oropenjpeg_v1_4_sources_r697) into /usr/local
>> ./configure --with-openjpeg
>> ./configure --with-openjpeg=/usr/local
>> both result in
>>    OpenJPEG support:          no
>> I wiped my gdal-1.8.0 directory and unpacked a fresh copy to make sure
>> nothing was cached.
>> I can see this test in configure output
>> checking for opj_decode_tile_data in -lopenjpeg... no
>> which does not look promising. Is there a version compat problem?
>> Brian
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Julien MICHEL
CNES - DCT/SI/AP - BPI 1219
18, avenue Edouard Belin
31401 Toulouse Cedex 09 - France
Tel: +33 561 282 894 - Fax: +33 561 283 109
