[gdal-dev] Does WMS TMS minidriver support a local path for <ServerURL>?
Even Rouault even.rouault at mines-paris.org
Fri Mar 18 16:11:20 EDT 2011
Le vendredi 18 mars 2011 21:00:12, Jeff Ruby a écrit :
> Hi,
> I've built a TMS structure using gdal2tiles.  I'd like to access the
> files directly not via a webserver.
> It appears the WMS TMS minidriver may be an option and I'd like to
> know if <ServerURL> supports reference to a local drive\path.
Yes, use file://a_directory_name
> Thanks much,
> -Jeff
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
