[gdal-dev] Does WMS TMS minidriver support a local path for <ServerURL>?
Jeff Ruby jgr007 at gmail.com
Mon Mar 21 15:42:37 EDT 2011
Hmmm...it doesn't seem to work for me.  I get the following error:
0ERROR 1: GDALWMS: Unable to download block 0, 0.
  URL: file:///c:/temp/7/0/0
  HTTP status code: 0, error: Couldn't open file /c:/temp/7/0/0.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
All my tiles are in c:\temp.  Below is my xml file:
<GDAL_WMS>
  <Service name="TMS">
    <ServerUrl>file:///c:/temp/${z}/${x}/${y}</ServerUrl>
    <SRS>EPSG:32618</SRS>
  </Service>
  <DataWindow>
    <UpperLeftX>224270.0</UpperLeftX>
    <UpperLeftY>3731360.0</UpperLeftY>
    <LowerRightX>226811.0</LowerRightX>
    <LowerRightY>3728689.0</LowerRightY>
    <SizeX>25088</SizeX>
    <SizeY>26624</SizeY>
    <TileCountX>49</TileCountX>
    <TileCountY>52</TileCountY>
    <TileLevel>7</TileLevel>
  </DataWindow>
  <Projection>EPSG:32618</Projection>
  <BlockSizeX>25088</BlockSizeX>
  <BlockSizeY>26624</BlockSizeY>
  <BandsCount>3</BandsCount>
  <Cache/>
</GDAL_WMS>
On Fri, Mar 18, 2011 at 4:11 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Le vendredi 18 mars 2011 21:00:12, Jeff Ruby a écrit :
>> Hi,
>> I've built a TMS structure using gdal2tiles.  I'd like to access the
>> files directly not via a webserver.
>> It appears the WMS TMS minidriver may be an option and I'd like to
>> know if <ServerURL> supports reference to a local drive\path.
> Yes, use file://a_directory_name
>> Thanks much,
>> -Jeff
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
